TwinTurbo.NET: Nissan 300ZX forum - Idle air screw is for base idle when the IACV is not plugged
MixManMash
on February 16, 2012 at 7:52 AM
maybe silly question, but isnt the purpose of the
posted by LJZTT
on February 16, 2012 at 06:13 AM
in or has failed. Normally, the ECU will try to control the idle air, but if too much is escaping past the TBs, not much it can do. So, no you can't compensate in that fashion.
Warning: crappy photos of my repaired Z1 TB's
zgene4
22:25:05 02/15/12
Sweet. (n/m)
BoneZ (MD)
22:47:07 02/15/12
I have in my hands a set of bored out stockers. See some
ztunerz
22:53:07 02/15/12
Awesome! (n/m)
Wright (Ca)
23:12:03 02/15/12
I'm glad you are happy with them
Rob'Z
23:19:44 02/15/12
Having done machining I can only imagine getting the angle
5280Z_nightstalker
01:24:21 02/16/12
Glad I didn't buy these...will await your quality 62mm (n/m)
LoqueZX(CA)
01:30:43 02/16/12
2nd! The timing worked out perfect for me.
Evan(CA)
02:06:50 02/16/12
Email sent. Not a far drive at all so let me know. (n/m)
LoqueZX(CA)
14:18:54 02/16/12
lemme know too! (n/m)
BlackholeZ
03:14:07 02/17/12
So what is the going price to fix the Z1 TB issues ? (n/m)
Xteam300TT (South Tx )
23:32:07 02/15/12
would love this info as well
jzx
02:06:37 02/16/12
Pricing will be the same for stock, 58 and Stanzas
Rob'Z
11:27:37 02/16/12
do the Z1 units use bushings or bearings? (n/m)
aliaZ
17:48:19 02/16/12
06:13:57 02/16/12
My Z idles between 850 and 900 with my first set of modified
Rob'Z
07:37:53 02/16/12
Idle air screw is for base idle when the IACV is not plugged -
MixManMash
07:52:37 02/16/12
The idle screw couldn't compensate enough for my first set.
Wright (Ca)
08:12:12 02/16/12
Thanks for the link, I couldn't find my own original pics
zgene4
10:06:21 02/16/12
lol.. what a POS (n/m)
Antihero
14:44:23 02/16/12
wtf, that has to be a joke (n/m)
17:52:37 02/16/12
Stick to... whatever you do, you suck at pictures :) (n/m)
08:25:22 02/16/12
lol, blurry was the only way I could get the amount of light
zgene4
10:08:40 02/16/12
yes...have emailed Rob while watching his progress....
Z ONLY1
08:44:23 02/16/12
Your z1's might be perfectly fine. It's normal to hear only
Wright (Ca)
09:59:09 02/16/12
I can't fix the crookedly tapped holes in the throttle shaft
Rob'Z
11:40:29 02/16/12
Yeah, I am thinking of pressure checking the seals...
Z ONLY1
13:11:21 02/16/12
supposedly...
ZXoltan
16:08:11 02/16/12
My new sets leak with less then 5psi. My first set did not
Wright (Ca)
16:33:02 02/16/12
if they are using similar chinese producers as AMS then
17:56:15 02/16/12
If you're Porto g your plenum might as well go to 62.
Rob'Z
11:35:57 02/16/12
excellent. hope this ends your long TB dilemma (n/m)
Ahmed (Chicago)
09:17:08 02/16/12
Good luck, Ryan!
Only1Z
18:00:32 02/16/12
